0 members (),
90
Mod | | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I got a Delco Remy 1994017 nos switch for my 1941 truck, was wondering where i can get the rod amd knob and not quite sure how the rod even hooks up does anyone know where i could find a pic of it. Thanks
David VCCA member | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I made my own. I had the threaded nut for the dash from a later model switch. Then I took thread all nuts and a nylon sleeve. I bent the rod. You can look at my photo bucket to find the pictures. | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Thanks for the info, i see it just pushes in the copper tab what size rod did you use? Is that a repo knob? Nice pictures sure like that blue, mine was originaly red not sure which color i'll go with, Thanks again | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am not sure on the rod size. It was one that just fit through the dash nut. Those are available through the parts house. I started with the bend long and did some trial fitting. I heated the rod and bent it, then threaded it. I'd check but its all installed now. Yes the knob is a repo. I had some after market switch and no knob when I bought the truck. | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Ok should'nt be to hard thanks again  | | |
