4 members (gswbbc, Steelonsteel, Otto Skorzeny, Cosmo), 95 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#895878 11/11/2012 12:33 AM
I got a Delco Remy 1994017 nos switch for my 1941 truck, was wondering where i can get the rod amd knob and not quite sure how the rod even hooks up does anyone know where i could find a pic of it. Thanks
David
VCCA member
crash2012 #896006 11/11/2012 2:40 PM
I made my own. I had the threaded nut for the dash from a later model switch. Then I took thread all nuts and a nylon sleeve. I bent the rod. You can look at my photo bucket to find the pictures.
crash2012 #896590 11/13/2012 11:10 PM
Thanks for the info, i see it just pushes in the copper tab what size rod did you use? Is that a repo knob? Nice pictures sure like that blue, mine was originaly red not sure which color i'll go with, Thanks again
crash2012 #896649 11/14/2012 8:05 AM
I am not sure on the rod size. It was one that just fit through the dash nut. Those are available through the parts house. I started with the bend long and did some trial fitting. I heated the rod and bent it, then threaded it. I'd check but its all installed now. Yes the knob is a repo. I had some after market switch and no knob when I bought the truck.
crash2012 #896853 11/15/2012 1:43 AM
Ok should'nt be to hard thanks again smile
