2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
#896223 11/12/2012 12:21 PM
Seems like a simple question -
Where can I buy a non-halogen 12v headlight bulb for my '54 3104 (converted to 12v)?
- Lonnie
My '54 3104
American Classic truck parts-click on the link to the left.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
if you have a NAPA around they should at least be able to order them in, around here they still have'em on the shelf
I needed one on my road trip to Galveston last month. O'Reilly's didn't stock them. So I bought 2 halogens. A great upgrade.
My simple question has become not-so-simple.
>> Having a hard time finding non-halogen 7" 12v headlight bulbs. Need two. Any suggestions?
American Classic only sells halogen. Same for the other usual suppliers.
NAPA shows non-halogen on line (6014), but store says that they are no longer available ... halogen only (6024).
I agree that halogen would be a good upgrade, but trying to stay old-school.
- Lonnie
My '54 3104
Lonnie,
Why would a 12v non-halogen bulb be more/less old school than a 12v halogen bulb? They are both sealed-beam like the 6v original (but neither are 6v original school).
Unless you are comparing to the high output halogen two-piece bulb/housing (non-sealed-beam but much brighter - available in 6v or 12v).
some sources of 12v non-halogen (maybe?) bulbs:
http://www.bughaus.com/karmann_ghia_light_bulbs.htm
http://www.taillightking.com/Headlight_bulbs.htm
http://glenssurplus.com/proddetail.php?prod=GE-6014
http://www.eisparts.com/6014/Headlight,Sealed+Beam,7%22,+12V.html
Yep - you caught me, Tim!
I think that I just don't want to see "Halogen" on the bulb. I found non-halogen bulbs on line at Do-It-Best hardware and can be shipped to the store. I'll check out this afternoon. Otherwise, I'll contact one of your sources.
Thanks for the links. Glens Surplus is new to me. Looks interesting.
A bit of useless info that I dug up ...
I believe that the original bulb that would have been in my truck was a 6v #6006. The 12v bulb in 55(2nd), 56, 57 was #6012 (40amp low/50amp hi). The 6012 was superceeded by #6014 (50amp low/60amp hi). The 12v halogen bulb is #6024.
I guess if I wanted a true '54, I should have had Ken Warner build a 6v gen for my truck instead of a 12v disguised as a 6v. I chould have converted it all back to 6v pretty easily. You're right - I'm not as old school as I pretend to be!
- Lonnie
My '54 3104
To close out the thread ... I bought two GE #6014 incandescent sealed beam headlights on-line from Do-It-Best Hardware for $4.39 each. Delivered to my local store with no shipping. The flutes in the center of the glass lens are a tighter pattern than the old 6014, 6012, or 6006 headlights. They kinda look like the flutes in a halogen headlight. Another example of me being "overly-picky". Anyway, the headlights are installed and burning. Bring on the night!
- Lonnie
My '54 3104
