| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | Anybody know of a good soda blasting company in the DFW area? I'm just getting started on a 42 shortbed chevy project and would like to hear from local bolters on good services ,parts ect
Thanks | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Talk with your paint store first. I was told if you soda blast you will have adhesion problems. Soda is basic and the primers are acidic and the soda will affect the adhesion. | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | you are correct. However Soda blasting leaves a protective film on the surace that inhibits rust. A good cleaning afterwards is a must for paint adhesion. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if there's any film left it wasn't done right, it must be immediately flushed thoroughly, and water doesn't inhibit rust, - soda blasting is really a paint removal technique, it doesn't remove corrosion and leaves too smooth a surface - most paint mfgrs will not honor any warranty if soda blasting was used, regardless if it was defective paint product, poor application, or sloppy soda blasting - see hereBill | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | thanks for the info and the link. appreciate ya | | |
