| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi I was wondering if someone can tell me what engine I have I just bought a 46 1/2 parts truck but it appears to have a different engine than my other one that has the origional engine in it which has the same # on the block behind the distributer as on the vin tag this engine has no # on the block behind the distributer and has larger spark plug holes other than that it looks identical the block # is 369337 with gm 48 stamped under it the head # is 838773 can anyone give me a heads up on this thanks
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1937-40 head block? What is the code that is pressed into the block, in the ledge to the rear of where the distributor goes into the lock? post the date casting codes for the head and block | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It is probably a replacement block that came from the factory with no engine serial number, or it is a replacement block that someone has ground off the engine serial number.
See if you can find/post the date casting codes.
| | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Ill have to check tommorow thx for your interest but the serial # area dosen't appear to be ground off unless less it was machined off | | |
