2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#896295 11/12/2012 8:14 PM
Hi I was wondering if someone can tell me what engine I have I just bought a 46 1/2 parts truck
but it appears to have a different engine than my other one that has the origional engine in it which has the same # on the block behind the distributer as on the vin tag
this engine has no # on the block behind the distributer and has larger spark plug holes other than that it looks identical the block # is 369337 with gm 48 stamped under it the head # is 838773 can anyone give me a heads up on this thanks
1937-40 head
block?
What is the code that is pressed into the block, in the ledge to the rear of where the distributor goes into the lock?
post the date casting codes for the head and block
It is probably a replacement block that came from the factory with no engine serial number, or it is a replacement block that someone has ground off the engine serial number.
See if you can find/post the date casting codes.
Ill have to check tommorow thx for your interest but the serial # area dosen't appear to be ground off unless less it was machined off
