| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89611 05/09/2004 2:32 PM | Joined: Apr 2004 Posts: 16 Apprentice | | Apprentice Joined: Apr 2004 Posts: 16 | Has anyone upgraded their 41-55 headlights? Looking for some ideas on what to do. I'm considering the sealed beam conversions with the H4 bulbs. The ones on ebay say they will fit any H6024, and list a ton of vehicles, why woudln't those fit my application?
41 Chevy Pickup 71 Jeep CJ5 99 GMC K1500 Xcab 00 Kawasaki ZR7 02 Saturn SL | | |
#89612 05/09/2004 4:18 PM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | [censored] artist who actually manufactured the sealed-beam-sized Xenarcs in his backalley junk shop. The Xenarc units intended for late-model Chevrolet trucks are not Taiwanese and are much better.
DS | | |
#89613 05/10/2004 12:46 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I put relays on my headlights ... and they're much brighter. How-To
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#89614 05/10/2004 2:58 PM | Joined: Apr 2004 Posts: 16 Apprentice | | Apprentice Joined: Apr 2004 Posts: 16 | My reasons for upgrading were for looks. I've already gotta buy new ones cause the system is 12 volt now. Plus a sealed beam conversion isi def. the way to go. The bulbs are cheap and easy to replace, plus the wiring is already set up for it (based on the donor chassi). All the $40 sets look to be non DOT approved so far. So I've started searching some of the webpages hoping to find some. I'd def. need them to be useful, not just for show.
#89615 05/10/2004 6:06 PM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | I'm not sure I understand what you want to do. The original 6 volt 6006 *is* a sealed beam lamp, and the 12 volt equivalent 6024 and H6024 (Halogen) are also sealed beam lamps. The 6024 and H6024 are physically identical to the 6006. They fit perfectly in the original mounting and have the same configuration for the electrical contacts.
H4 bulbs and the housings they fit into are *not* sealed beam units. Many people (including myself) consider the bluish light they emit to be very annoying, and this is compounded by the fact that they are almost never aimed properly.
If you're after something that works well, I'd say go with the H6024 Halogen lamps, which are a bolt-in replacement for the originals.
Joe | | |
#89616 05/10/2004 9:58 PM | Joined: Apr 2004 Posts: 16 Apprentice | | Apprentice Joined: Apr 2004 Posts: 16 | That's pretty much what I was hoping to find out. I didn't know the 6006 and 6024 were the same and couldn't get that verified anywhere. I don't like the look of H6024 (halogens) at all. I am planning on going to the H4 Sealed Beam Conversions, but am making sure it is a DOT approved setup. Drives me nuts havin misaimed headlights too. and I also wanna be able to see at night. I've found a couple DOT sets for around $50 plus shipping. Guess I'll bite the bullet and pay the extra 20
#89617 05/10/2004 11:14 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :confused: What was the first year for sealed beams on Chevrolet trucks?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#89618 05/11/2004 12:47 AM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Originally posted by JhnBrackett: ...I don't like the look of H6024 (halogens) at all... You don't like the light they put out, or don't like the appearance? Visually, they are identical to the original 6 volt sealed lamp. You have to be about 2 feet away to see any difference in the logo cast into the glass. Here's a photo of my truck with H6024 bulb. [img] http://www.brakecylinder.com/images/52chevy/headlight.jpg[/img] The light is brighter than a standard 6024 on 12 volts or 6006 on 6 volts, but does not have a noticeably different color. Joe | | |
#89619 05/11/2004 4:40 AM | Joined: Apr 2004 Posts: 16 Apprentice | | Apprentice Joined: Apr 2004 Posts: 16 | I can see how that can be taken 2 ways. i meant I don't like the yellowish light emitted. And for style I do like the H4 Euro Cuts
#89620 05/11/2004 2:05 PM | Joined: Apr 2004 Posts: 13 Junior Member | | Junior Member Joined: Apr 2004 Posts: 13 | Hella or Cibie E-Codes. I also have a set of H4's I got from a VW Mag ad. For $7 (w/bulb) I had to try them. The compare to the Hellas and have a glass lens. I promptly added 100w hella bulbs, that cost more than the lamps, but give twice the light on bright. The do not have the blue "Rice boy" tint. The Hellas have a Flat lens which IMO will not flow with the 49-55 front end. Works with the 1964 Brick though. :rolleyes: | | |
#89621 05/11/2004 2:37 PM | Joined: Apr 2004 Posts: 16 Apprentice | | Apprentice Joined: Apr 2004 Posts: 16 | I hadn't thought about the curve going with the body, probably a good idea for me w/ a 41. How's the beam pattern on the $7 set, got a link to get them?
