2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#895882 11/11/2012 12:54 AM
I have a brand new Carter W-1 just sitting around the shop. In the 64', is a Rochester on the 230 that is starting to act up, and my question is can this be transplanted in place of the Rochester, and what differences would I have other than using the older model oil bath air cleaner vs. that paper element air horn box I have now? Thanks for any help.
Tramp
dj durant
More pix on Flickr
Tramp #895889 11/11/2012 2:28 AM
Are the base bolts the same? I don't think they are.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Tramp #895904 11/11/2012 7:15 AM
I don't think the W1 would work on you're 64 for one it's port vac and you need manifold vac for you're distributor.Also the W1 is for a smaller engine a 216.
Look for a Carter # 3770S for auto trans or a Carter # 3771S for a manual trans both of them are for a 230 in 64.
Pete
Tramp #895988 11/11/2012 1:12 PM
OK and thanks. I'll hang onto the Carter and use it when I put the 38' back together. In the meantime,I'll have to keep tinkering with the Rochester and start looking for something to replace it with. Bout' done with the truck, so it's time to start something new. Have to wait and see what my therapist says about that idea.
dj durant
More pix on Flickr
