| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I have a brand new Carter W-1 just sitting around the shop. In the 64', is a Rochester on the 230 that is starting to act up, and my question is can this be transplanted in place of the Rochester, and what differences would I have other than using the older model oil bath air cleaner vs. that paper element air horn box I have now? Thanks for any help. Tramp | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Are the base bolts the same? I don't think they are.
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I don't think the W1 would work on you're 64 for one it's port vac and you need manifold vac for you're distributor.Also the W1 is for a smaller engine a 216.
Look for a Carter # 3770S for auto trans or a Carter # 3771S for a manual trans both of them are for a 230 in 64.
Pete
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | OK and thanks. I'll hang onto the Carter and use it when I put the 38' back together. In the meantime,I'll have to keep tinkering with the Rochester and start looking for something to replace it with. Bout' done with the truck, so it's time to start something new. Have to wait and see what my therapist says about that idea. | | |
