4 members (cmayna, 52Carl, CATMAN, J Lucas), 126 guests, and 2 robots.
Topics128,195
Posts1,057,380
Members48,471
Hi all,
I just bought a new master cylinder/brake booster kit for my 1954 3/4 ton Chevy truck. I am keeping the truck drum brakes all the way around to try to keep as original as possible. I upgraded because the original master cylinder is just too scary for me with all the money I have in this truck. Anyway the kit came with two 10 lb proportioning valves for the rear brakes. My question is how important our these valves? I know they are to reduce the pressure and I'm going to put them on, but I was just curious. Thanks
Riding in the Passing Lane
They are very important with the master cyl. under the floor. You want one on the front drums & one on the rear. This keeps a small amount of pressure on the wheel cyls. to keep from drawing in air on retraction. Front discs can use a 2 lb. valve.
1972 Chevy c10 Cheyenne Super
So it came with 10LB valves. Where do I put them? Is it okay to just put them somewhere in the brake line on the front and the rear or do they need to be closer to the master cylinder? Thanks
Okay so I screwed up it came with 2 10 LB residual valves NOT 10 LB proportioning valves. Sorry about that. So what do these valves do and where should I put them? Thanks again.
I didn't even catch your mistake. I assumed residual valves. The same advice applies.
Put one in the line to the front & one in the line to the rear.
okay thanks
