2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#8955 07/27/2004 12:03 AM
I recently found a complete SM420 in a pile of scrap metal at the local dump. What luck! I had been looking for one to replace the 3 speed in my 1952 3100 1/2 ton and literally tripped over this SM420, shifter and all.
I'll be converting the truck to a open driveline and already have a good rear end to put in as well. I have read a number of archived posts here about the SM420, but I still have a few unanswered questions:
I read that the SM420 will bolt up to my 235 bellhousing - but will I need to change the clutch?
Is there a transmission tunnel for the cab that was made for this trans?
And lastly, do I need a transmission crossmember to support the weight of the trans? Was there one in 1952?
If anyone who has rebuilt this trans and/or done this swap has any tips, I'd love to hear them as well. Thanks in advance for your help!
Keahi
#8956 07/27/2004 12:42 AM
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks! I don't know how I missed that page. How rare are the transmission covers?
That site shows the conversion on a later model Suburban. Some of the details will be different on your 52. I think that the clutch will be different from the 3 speed setup. My clutch on my 1 Ton is the larger 10 3/4" clutch.
There is no special tunnel on the 52. I think that the cab should fit fine. The transmission cover will be different.
1951 1 Ton Completed
MOst of the major venders have the 4spd tranny cover (made out of fiberglass) for 40- 50 bucks.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
The clutch can be the same, but most trucks equipped with an SM420 had a larger clutch. My 216 equipped factory SM420 '50 truck had a standard 9" clutch.
Paint & Body Shop moderator
Look closely at the output end of your 420...is it set-up for open driveshaft, or does the u-joint sit in a cast-iron dish with four ears & bolt-holes, to mate with the torque-ball on the driveshaft?
All '47-'54 Chevy trucks have flat floors (no tranny tunnels), and the tranny-to-bell housing bolt pattern is the same for all trucks from '47 - '66...
You will need to get the floor-shift center floor cover.
Also, the speedo might read incorrectly with the four-speed...the 420 was available in ALL sizes of Chevy trucks, from 1/2 ton thru 2 ton, which covered a range of rear end ratios of 4.1 for the half-ton through 6-something for the 5400 & 6400 series trucks...
Good luck with it !
cool
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Thanks to everyone! It's an open driveline trans - off a 1961 if I decoded the casting numbers correctly. However, I wouldn't mind getting the necessary parts to connect it to the torque tube so that I can just bolt the trans up now and then change the rear end and driveshaft in a future weekend project. Maybe I'll put a request in the swap meet section.
Aloha,
Keahi
