0 members (),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | When I got my 58 Apache there was no heater in it. I have a Harrison 10 57 HD 02 58B and it fits, mounting studs and heater core pipes line up with origanal holes. There are no round ports on the box for the deforster hoses, looks like there should be another part that goes on the square end where the air flow exits with the round ports on it. I can't find this box on the net, can anyone ID it. If it needs another part for the deforster where can I get it. I can email pics of the unit if needed.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | without a picture .... no, but it might be part of a heater - for what the 55-59 heaters look like, see hereBill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's the "standard" heater in my '58, the defrost hoses come out at the end of the top left and that lever with the black knob controls a flap to direct the air to the floor or to the defrost .... yes, you have something missing, where the 3 screw holes are in your end view picture, but I'd have to study mine a bit to see what - for one, there should be a sheet metal bracket there that attaches to the lip of the dash
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | It also looked to me that another piece was needed to attach to the end with the three screw holes. Need to find that piece and also the bracket that you mentioned.Would like to see a pic of it so I know what I'm looking for.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I can look tomorrow, not sure I can get much of a pic up under there but maybe some measurements
Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Thanks. I appreciate it. Going to a swap meet tomorrow in Rossville, GA. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sorry Tech, I got bogged down at work today and didn't get a chance to get outside, will do it tomorrow fer sure
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | tried a bunch of pictures, but not much can be seen cuz it's a mess crammed in there on mine - try a description - on your last pic looking into the end of the air chamber, there should be a "cap" piece on the hole at the bottom that has the defrost tubes on it, pointing toward the firewall - the bracket to the dash goes on top of that and both are held on by the 3 missing screws - short of finding the correct pieces I'm not sure it could be fabricated, and short of having one apart good pics or measurements would be tough  Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Tech - I tried some more pics and got one sort of from the same perspective as yours here - the bracket should attach to the underside of the dash where the patch is, I just hooked it over the lip and never dug up the missing fasteners - the tubes are an odd size so I found that elbow piece to adapt to one and the other is duct-taped  hope that helps you figure what you need Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | Red58 The pic helps. I thought that the missing piece would have come straight out from the air flow opening. Your pic shows that it goes up above the box, that helps me. Now I need to find it. I looked all over the net with no luck, you would think that someone is making that style box, and I should be able to get it from them. Thank you for all your help. I have posted a bunch of pics on photobucket of my 58 Apache under navycwo4 account. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no repros of any part of the original heater boxes that I know of, it's the cores that everyone usually needs, you might end up having to fabricate something .... good luck with it  Bill | | | | | Joined: Aug 2012 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 53 | | | |
