2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | I have a '51 216.5 ci. I've read different info about motor oil and which grades should be used. I live in MD so no extreme temperatures and I drive the truck weekly around town. What motor oil should I be using? | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I would run 10/40 weight. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I second the 10-40. No need for special oil on a well worn engine. Change it regularly and you should be fine.
Joe | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Agree with the above comments. I use 15W40 and change it regularly. For trucks that are just driven now and then, I change it several times a year and not wait for 3000 miles. That seems to work the best.
| | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | Great. Thanks all for the advice. I will do exactly that. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I put maybe 1000 miles a year on my truck, so I will only start it when I know its going to be driven long enough to dry the oil and tail pipe of any condinsation that may have collected in them. I change oil about every two or three years, kinda depends on how it looks or if I feel like it.
Joe | | |
