2 members (mason86, Gray_Ghost), 110 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
#895033 11/06/2012 11:13 PM
I have a '51 216.5 ci. I've read different info about motor oil and which grades should be used. I live in MD so no extreme temperatures and I drive the truck weekly around town. What motor oil should I be using?
I would run 10/40 weight.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
I second the 10-40. No need for special oil on a well worn engine. Change it regularly and you should be fine.
Joe
Agree with the above comments. I use 15W40 and change it regularly. For trucks that are just driven now and then, I change it several times a year and not wait for 3000 miles. That seems to work the best.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Great. Thanks all for the advice. I will do exactly that.
I put maybe 1000 miles a year on my truck, so I will only start it when I know its going to be driven long enough to dry the oil and tail pipe of any condinsation that may have collected in them. I change oil about every two or three years, kinda depends on how it looks or if I feel like it.
Joe
