4 members (Phak1, 2-Ton, Gdads51, Wayne67vert), 36 guests, and 1 robot.
Topics128,022
Posts1,055,360
Members48,420
#894637 11/05/2012 3:14 PM
Hey, I'm wondering if anyone has a diagram of what goes through what hole in the firewall. I'm trying to assemble a former basket case, and it would sure be helpful. Yeah, I know I need to purchase an assembly manual, but haven't gotten around to it yet.
Thanks guys, and great site!
Larry, people will need to know what kind of truck, and the year of it.
Brian
1955.2 3100 Truck
Socket Breaker
Socket Breaker
The 'bolt covers trucks from 1916 to 1972, so as 55 Shaker mentioned... if you want a useful answer, we are going to need more information.
kinda info we need:
year model
chevy or gmc (some of the older trucks had very different wiring setups between the two)
model number for ton rating
engine, trans, any known modifications may be an issue as well.
-W
Looking at Larry's previous posts he has a 49 Chevy.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
People asking for advice shouldn't expect people to look up their previous posts.
jmoore #894753 11/05/2012 10:21 PM
Hi Larry -
Gotta get a Factory Assembly Manual. You'll drive yourself crazy without one. The info that you want is in the '47-'54 Factory Assembly Manual. I assume that it is the same for your '49.
> Section 1, Sheet 3.19 - firewall
> Section 12, Sheet 1.00 - Gauges and harnesses (may be difficult to see)
> Section 12, Sheet 1.001 - Speedo and wiring harness clip. Different clip shown in same Sheet Number on right side of manual.
> Section 12, Sheet 4.05 - brake light switch
> Section 12, Sheet 5.00 - Voltage reg, fuse box, horn relay (if your '49 has one), wiring harness.
> Dual clip for speedo cable and wiring harness, Sect 12, Sht 1.001 - American Classic Truck Parts part # FA-113
> Here is the firewall in my '54. Mostly set up to diagrams in the FAM. Exceptions:
> '54 Horn relay should be mounted on left side of fuse box
> Empty grommet is for vacuum hose for windsheld wipers. My truck has electric wipers.
- Lonnie
My '54 3104
Correct. Sorry about that, I have a '49 chevy half ton. I this is helpful, thank you. I'll get the assembly manual, too. nice to finally be putting stuff back on the truck instead of taking it off!!
