5 members (Otto Skorzeny, KEVINSKI, Hanks custodian, SmalltownTRKGuy, 1 invisible), 69 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#89463 12/09/2001 11:32 PM
Hello Folks, Here it goes, replaced an alternator that was bad, then after letting truck idle for about five minutes, shut down. Then realized fuel pump leaking badly. Replaced with new pump. Now I have gas in carb, even shot a little ether to be sure, no spark at all. Iginition is on in cab. Where should i go from here. I have a simplified 12 volt system.(My dad and i converted 15 years ago, but since i was 10, don't remember much about it. Is there a way to see if i'm getting spark, or can i put my voltmeter on coil to take measurements? Any help would be appreciated.
They're more fun shared with others (the trucks that is)
#89464 12/10/2001 12:08 AM
You should have 8 or 9 volts at the small wire on the coil(both sides).If not, start tracing the wire back ,,,ballast resistor(both sides),,,and go back to the ign switch.
Most likely something simple.Keep us informed of your progress!
#89465 12/10/2001 12:54 AM
Well Luke,
She's running happily in the drive right now. After your help, i grabbed the meter and started testing, on the terminal closest to the firewall i had knocked off the wire while doing some fuel line work. Thanks for your help!!
Ed - 51 3800 Panel grin
[ 12-09-2001: Message edited by: pnltrk380051 ]
#89466 12/10/2001 7:14 PM
Good to hear.
So, when do we get to see more pics of your 1-ton panel??? grin
#89467 12/11/2001 1:38 AM
as soon as i figure out how to use my new scanner to post things on the net, i'll post em up. I do have some coverage in Wheels of Time, but it's been some years. I think you guys will like this one, it was used to haul caskets from southern ohio to parts north. The guy who first owned it made wooden caskets and it was his haul truck. Probably why it's in such good shape for a one ton. Most of them that I see look beat to h***!! :p
