4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89438 04/18/2003 3:15 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Can any one tell me, Im puting a voltage reducer on my 50 Chev 12 volt for the gas gauge, can I install it in the power line to the gauge or right on the gauge.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#89439 04/18/2003 6:06 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | As long as you have the resistor somewhere between the power source and the positive terminal on the gauge, the proximity doesn't matter.
edit: Some resistors require a connection to ground, so that will limit installation options. | | |
#89440 04/18/2003 1:30 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | the voltage regulator should be hooked to the input side of the voltage stablizer, | | |
#89441 04/18/2003 7:46 PM | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | These guys are right. Just put it in between the power source and the guage. Good luck. | | |
#89442 04/19/2003 1:32 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Thank you guys for all the great input you answered everything.
