6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#89438 04/18/2003 3:15 AM
Junior Member
Junior Member
Can any one tell me, Im puting a voltage reducer on my 50 Chev 12 volt for the gas gauge, can I install it in the power line to the gauge or right on the gauge.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#89439 04/18/2003 6:06 AM
As long as you have the resistor somewhere between the power source and the positive terminal on the gauge, the proximity doesn't matter.
edit: Some resistors require a connection to ground, so that will limit installation options.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#89440 04/18/2003 1:30 PM
the voltage regulator should be hooked to the input side of the voltage stablizer,
#89441 04/18/2003 7:46 PM
Junior Member
Junior Member
These guys are right. Just put it in between the power source and the guage. Good luck.
#89442 04/19/2003 1:32 AM
Junior Member
Junior Member
Thank you guys for all the great input you answered everything.
