1 members (MikeE), 121 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
#89427 05/22/2005 6:43 PM
Yesterday I was driving the truck all day when in the afternoon (after stopping at a store for 10 minutes) the truck died.I do use a disconect switch all the time if I am not in the truck. I opened the hood and saw oil coming out of the (new) coil, I let it cool down and truck started and died again. Why is the(new)coil overheating? Jo
#89428 05/22/2005 7:14 PM
1 Offline
Do you have a resistor in the ignition?
1957 Chevy Stepside
1993 GMC Sonoma
#89429 05/22/2005 8:09 PM
New coil? What kinda coil?
Buzz'n Half Dozen
#89430 05/22/2005 8:28 PM
The Truck is stock 6 volt. The coil is an Echlin Standard. Truck has run for weeks with no problem. jo
#89431 05/22/2005 8:37 PM
gen is putting out too much voltage? [like bad regulator]
ignition resistor shorted out and is putting full voltage to the coil?
check resistance across the resistor and voltage at the coil
#89432 05/23/2005 12:55 AM
I have never seen a 6V with an ignition resistor. Did you install the coil upside down?
Jason
#89433 05/23/2005 1:24 AM
Jason, I do not have a resistor installed.
The coil is installed with the cables on top as it will not leak that way. jo
#89434 05/23/2005 6:33 PM
Can you measure the resistance between the + and - terminals? Should be near 1.5 ohms. Maybe it has developed a short.
Jason
#89435 05/24/2005 3:12 PM
Your best bet is to replace the DOA coil with an NAPA Echlin IC7. It will have the ballast resistor built in and has proven to be very reliable. It is all I have used for 6 volt projects for the past ten years...Thanks Randy
#89436 05/24/2005 3:13 PM
#89437 05/24/2005 11:22 PM
Thanks for the advice Randy
