2 members (klhansen, 1 invisible),
88
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89427 05/22/2005 6:43 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Yesterday I was driving the truck all day when in the afternoon (after stopping at a store for 10 minutes) the truck died.I do use a disconect switch all the time if I am not in the truck. I opened the hood and saw oil coming out of the (new) coil, I let it cool down and truck started and died again. Why is the(new)coil overheating? Jo | | |
#89428 05/22/2005 7:14 PM | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Do you have a resistor in the ignition?
1957 Chevy Stepside 1993 GMC Sonoma
#89429 05/22/2005 8:09 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | New coil? What kinda coil?
Buzz'n Half Dozen
#89430 05/22/2005 8:28 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | The Truck is stock 6 volt. The coil is an Echlin Standard. Truck has run for weeks with no problem. jo | | |
#89431 05/22/2005 8:37 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | gen is putting out too much voltage? [like bad regulator] ignition resistor shorted out and is putting full voltage to the coil? check resistance across the resistor and voltage at the coil
Bill | | |
#89432 05/23/2005 12:55 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I have never seen a 6V with an ignition resistor. Did you install the coil upside down?
Jason
#89433 05/23/2005 1:24 AM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Jason, I do not have a resistor installed. The coil is installed with the cables on top as it will not leak that way. jo | | |
#89434 05/23/2005 6:33 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Can you measure the resistance between the + and - terminals? Should be near 1.5 ohms. Maybe it has developed a short.
Jason
#89435 05/24/2005 3:12 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | Your best bet is to replace the DOA coil with an NAPA Echlin IC7. It will have the ballast resistor built in and has proven to be very reliable. It is all I have used for 6 volt projects for the past ten years...Thanks Randy | | |
#89436 05/24/2005 3:13 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | Your best bet is to replace the DOA coil with an NAPA Echlin IC7. It will have the ballast resistor built in and has proven to be very reliable. It is all I have used for 6 volt projects for the past ten years...Thanks Randy | | |
#89437 05/24/2005 11:22 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Thanks for the advice Randy | | |
