1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Hi - I'm a new owner of a '51 GMC 1/2 ton that no longer has it's original 216.
I've been guided to add a '55 or later 235 engine, trans, and rear end.
Is this pretty much a bolt in procedure? If not, what tasks or modifications do I need to know about? Thanks - Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Hi - I'm Dickson in Denver and I have a "new" '51 GMC 1/2 ton. It's a pretty solid cab and bed, complete except for missing it's original engine. I've restored 60's mustangs and 70's Alfa before, but this is my first vintage truck. I'm thinking of adding a '55 or later engine/trans/rear end. I plan to repaint, recover seats, and get her back on the road looking good. Thanks in advance for any help or encouragement! Dickson 51 GMC
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Welcome to the Bolt' A good upgrade would be the 302 GMC six, hard to find and pricey, but a great engine with power. The 270 is a good option. I am in the process of installing a 302 and a 4 speed overdrive, it will have a 1959 rear end with 3:90 gear ratio. Just to let you know if you aren't aware, the Chevy 235 engines are shorter than the GMC'S. Old POST on same subject. GMC Casting Numbers | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | First a GMC would not have a 216, more likely had a 228 or... Putting a 235 in is no problem except they are about 1 1/2" shorter so the front engine mount needs adapting.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Personally I would stick with a GMC engine. Preferably a 302, in my opinion, really, really preferably.... | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It might of had a 216 in it if it were a Canadian truck,than it will be a easy to install the 235.
Pete | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Thanks a lot guys. This is why a newbie has to ask!
I'll start looking for a 302...
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I would advise another 228 or 248 perhaps. Just don't get caught up in the "bigger is better" mentality or you'll go off course. Understand first what you expect from this truck, why you have it, what level of expertise and dollars you can approach it with. There is absolutely no reason to have a huge engine that was never used in your truck as a replacement for what it was designed and engineered for. Yes, it will fit in the space..but that is only the start of things to come. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The cost to rebuild the engines are about the same, so why not go bigger? More power, and can be made into a performance engine with available parts. He is also located in Colorado, so power would be a good thing for those mountain roads. REBUILT 228 | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Cool, a long-wheelbase 1/2-ton. Way to go. Good luck with it. Have fun but be safe.
Is it a Canadian truck? It seems that lots of them ended up in the Lower 48.
Professional Novice
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Are you sure it's a 1/2 ton. Check your vin on the driver's door cowl. Chevy long beds were not mfg in the USA, only Canada and Australia.
~Jim
| | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Thanks Frank. I really have no idea about the history of the truck, but I'm excited to work on it and enjoy getting it back on the road.
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Don't know Jim. That's what I was told...I'll check the data plates & decode.
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Are you sure it's a 1/2 ton. Check your vin on the driver's door cowl. Chevy long beds were not mfg in the USA, only Canada and Australia. It is not a Chevy. Long bed GMCs are common. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Guess I should improve my reading skills.
~Jim
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Dickson, If you want real bragging rights, you might consider a Cleveland..........but seriously, if it's a GMC stay with a GMC power plant. What are your long term plans for the truck?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I would also look for a GMC 270 or 302, S. N. on starboard side of block, Stamped on machined pad to rear of distr., displacement in first 3 numbers of S. N., i.e. 302xxxx. All GMC's from 228 on look the same, most yards don't know the difference, so just look around yourself.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I wouldn't really consider 302 cubic inches to be "huge" adequate maybe, but not much more. Lets face it, the performance of any of these sixes even under the best circumstances isn't all that earth shattering. Unless you are going with a 12 port head, forced induction of some kind, or something along those lines, that cost lots o'money. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | If he was looking for "huge" or "earth shattering" he wouldn't be considering a 235. We don't all race our trucks. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | No one is trying to coerce anyone toward any engine as I see it, just talking about what they would do. In my mind it's good education for a rookie in this hobby.
~Jim
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | No one is trying to coerce anyone toward any engine as I see it, just talking about what they would do. In my mind it's good education for a rookie in this hobby. Well put.
