1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#893239 10/30/2012 12:16 PM
Has anyone heard of "Vacuum Chroming"? This local company says they can chrome any material. Sounds too good to be true.
54John3100 #893243 10/30/2012 12:29 PM
it's how they "chrome" plastic, more appropriately called metallizing .... don't know how well it'd work on things like bumpers or other exterior pieces subject to abuse
54John3100 #893326 10/30/2012 5:21 PM
Basically it's wrapping a sheet that looks like chrome over your part. You're better off with actual chrome.
My 46 GMC on Photobucket
54John3100 #893339 10/30/2012 6:25 PM
Depending on cost it may be good for some interior small pieces. Just saying.....
54John3100 #893525 10/31/2012 10:46 AM
Compared to the look of actual chrome, I would say actual chrome is well worth the money. Just my 2 cents.
54John3100 #893547 10/31/2012 12:30 PM
It must not weather well because they clear coat over it.
I want to chrome my grill but there are a couple of dents i need to fix. Someone say to soldier the dents and smoothen as you would Bondo.
54John3100 #893552 10/31/2012 12:43 PM
if you're going to have a shop chrome the grill they'll fix the dents, check around - I don't think solder as a filler would take the chrome the same as the steel
54John3100 #893689 11/01/2012 10:44 AM
Being as they'll clean it and prep it before chrome, the solder will probably come out at that time. Talk to the chrome shop about prep.
54John3100 #893713 11/01/2012 12:17 PM
One of the Vancouver company sites I visited, called it soldering but that could be an industry term.
I agree, solder or the old school lead probably wouldn't work.
54John3100 #893727 11/01/2012 1:02 PM
Maybe the Chrome shop is talking about brazing ?
I agree with other comments - let the Chrome guys fix the dents - then, if you have a problem they can't point fingers at you.
Have you looked into Powder Coating ? There is a shop in Port Kells that claims they can coat anything. Samples I saw of headers and trim looked pretty good.
1940 Chevy KC 1/2-Ton
