| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Has anyone heard of "Vacuum Chroming"? This local company says they can chrome any material. Sounds too good to be true. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's how they "chrome" plastic, more appropriately called metallizing .... don't know how well it'd work on things like bumpers or other exterior pieces subject to abuse Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Basically it's wrapping a sheet that looks like chrome over your part. You're better off with actual chrome. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Depending on cost it may be good for some interior small pieces. Just saying..... | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Compared to the look of actual chrome, I would say actual chrome is well worth the money. Just my 2 cents. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | It must not weather well because they clear coat over it. I want to chrome my grill but there are a couple of dents i need to fix. Someone say to soldier the dents and smoothen as you would Bondo. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're going to have a shop chrome the grill they'll fix the dents, check around - I don't think solder as a filler would take the chrome the same as the steel
Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Being as they'll clean it and prep it before chrome, the solder will probably come out at that time. Talk to the chrome shop about prep. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | One of the Vancouver company sites I visited, called it soldering but that could be an industry term. I agree, solder or the old school lead probably wouldn't work. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Maybe the Chrome shop is talking about brazing ? I agree with other comments - let the Chrome guys fix the dents - then, if you have a problem they can't point fingers at you. Have you looked into Powder Coating ? There is a shop in Port Kells that claims they can coat anything. Samples I saw of headers and trim looked pretty good.
