8 members (Joe H, Joe Lowe III, frogfarmer, Shade Baby, 3B, Oswald, Cosmo, 1 invisible),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Bought a 57 235 to replace a spash oiled 235 in my 45 1.5 ton truck. Previous Owner pulled out the pushrods without labeling them. (Why? heck if I know) I've heard they should go back in the same holes they came out of. How critical is this? Or can I put them back in anywhere and reset the lash? (Solid Lifters)
BTW the engine is a low milage rebuild previously adapted to a 53 Pickup, so all the mounts are in the right place! Guy decided he had to have a V8. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is not a big deal. The valves may become noisy at first as they wear in, but I doubt it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Pushrods aren't critical at all, as long as the ends aren't showing significant wear. The lifters absolutely must stay with the cam lobes they ran-in on, so if it's ever necessary to remove them, or turn the engine to an angle where they might fall out of their bores, take them out and label them so they can go back into the same hole they came out of. Jerry
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Mr. Jerry and Dave are right! Push rods dont need to go back in the holes they came from, But the lifters MUST. Check for straightness and wear,If good put them in where you want. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Great! Lifters are still in, so no problem there. | | |
