3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | I bought a driver side rear fender with an indent for a side spare tire on my 52 short bed. The center fender support is attached with two rivets and leaded smooth on the outside. There is also an additional hole at the bottom verticle surface. Was this factory or a creative previous owner?My passenger side fender has a detachable fender support with two holes for bolts.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Any that I've seen used carriage bolts, I believe. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | The rear fenders of my '54 3104 are connected to the Rear Fender Center Brace with two rivets directly above the wheel opening. The rivets are shown in the '47-54 Factory Assembly Manual Sect 11, Sheet 19. Rear fender installation starts with running boards on Sect 11, Sheets 17.00 - 19.00. They are visable / not leaded smooth.
RPO 341 Side Mounted Wheel Carrier Instructions are in Sect 10, Sheets 3.00 - 3.02.
Perhaps a previous owner drilled out the rivets to repair / replace a fender.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | Thanks Lonnie. I will consult the manual, which I probably should have done first. Tom | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | brassbolt,
If you are going to try to find the side-mounted spare wheel-carrier mounting bracket, the 1953 bracket assembly is slightly different from the 1954/55 assembly, due to the angled shape of the 1953 (and earlier) bed-sides.
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | brassbolt Also, if you find a mount, most of them are missing an angle iron bar that is mounted horizontally on the backside of the bedsides - attached with the lower bolts in the vertical bars. Samantha | | |
