5 members (Joe H, HandyAndy, Gdads51, 3B, dt235sd), 122 guests, and 1 robot.
Topics128,049
Posts1,055,693
#892879 10/29/2012 7:38 AM
I bought a driver side rear fender with an indent for a side spare tire on my 52 short bed. The center fender support is attached with two rivets and leaded smooth on the outside. There is also an additional hole at the bottom verticle surface.
Was this factory or a creative previous owner?My passenger side fender has a detachable fender support with two holes for bolts.
brassbolt #892917 10/29/2012 10:44 AM
Any that I've seen used carriage bolts, I believe.
My 46 GMC on Photobucket
46gmcpu #892950 10/29/2012 12:01 PM
The rear fenders of my '54 3104 are connected to the Rear Fender Center Brace with two rivets directly above the wheel opening. The rivets are shown in the '47-54 Factory Assembly Manual Sect 11, Sheet 19. Rear fender installation starts with running boards on Sect 11, Sheets 17.00 - 19.00. They are visable / not leaded smooth.
RPO 341 Side Mounted Wheel Carrier Instructions are in Sect 10, Sheets 3.00 - 3.02.
Perhaps a previous owner drilled out the rivets to repair / replace a fender.
- Lonnie
My '54 3104
brassbolt #892991 10/29/2012 2:48 PM
Thanks Lonnie. I will consult the manual, which I probably should have done first.
Tom
brassbolt #892994 10/29/2012 2:52 PM
brassbolt,
If you are going to try to find the side-mounted spare wheel-carrier mounting bracket, the 1953 bracket assembly is slightly different from the 1954/55 assembly, due to the angled shape of the 1953 (and earlier) bed-sides.
brassbolt #893080 10/29/2012 9:11 PM
brassbolt
Also, if you find a mount, most of them are missing an angle iron bar that is mounted horizontally on the backside of the bedsides - attached with the lower bolts in the vertical bars.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
