1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | hey all
i bought some very cool vintage nos cab lights to go on top of the cab on my 1946 2 ton. they are green, which is allowed in california on old trucks (i checked the vehicle code)
my question is about spacing. I have 5. is there any standard spacing? the middle 3 are always closer together, but I dont know if there is any standard, or just go with what looks good.
any help would be appreciated
best regards | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | i guess the three in the middle are identification lamps, and in california: 25351 (a) A commercial vehicle and, except as provided in subdivision (d), any other vehicle 80 or more inches in width may be equipped with identification lamps mounted on the front or rear. No part of any such lamps or their mountings on the front of a motor vehicle shall extend below the top of the windshield.
(b) Identification lamps on such vehicles manufactured prior to January 1, 1968, may exhibit either amber, green, or white light to the front and red light to the rear.
the middle is obviously on centerline, but are the others spaced out at 6 inches?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Take a look in the Gallery at the 1946 big trucks...there are lots of trucks with either three in the middle or two on the corners. I didn't see any using 5... Mike B  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there is a definite DOT standard, the 3 identification lights are spaced at 6-12" in virtually every jurisdiction world wide - the additional 2 marker or clearance lights, are mounted as near as practical to the outside, any other arrangement is some wannabe trying to run with the big dogs .... the ID lights weren't a federal requirement in the 40's, but I believe the clearance lights were Bill | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....its so nice to learn something new everyday. Just leave it to the Stovebolt. I enjoy learning and this "light" post has been, shall we say, "enlightning".
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I was just thinking about cab lights last night while removing the remnants of the 3 on my 6400. Already have numerous replacements and hadn't decided on 3 or 5... took a look through the gallery just now and of the trucks that have them 3 is more common than 5, and to my taste the trucks with 3 look much better than those with 5.
Looks like I'll be using 3 again.
Grigg | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've alway thought two looked better on the '47-'55 trucks. I've seen more '41-'46 trucks from my area with the older three light cluster bar clearance lights. | | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the lights aren't matters of taste like paint colors, they're mandated by the DOT for a reason > identification of vehicle size in poor visibility conditions -safety- the federal statute was passed [1968] to standardize Conspicuity Systems, note it specifies identification lights to be exactly 3, the Canadian rules are the same, and although the clearance lights started earlier there was no previous reg that specified fewer ID lights .... the page Jake shows is what was done from the factory by the 60's on trucks that were the 80" width specified Bill | | | | | Joined: Jun 2009 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 79 | Generally the center 3 ( called idenification lights )are on 6" center spacing while the two outer ( called clearance lights )are as far out on the cab roof as possible. Those are still the DOT regulations to this day  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | But the way I understand it if you want to restore your old truck (pre 68) as it was, with only corner lights, you can do so.
Mine's under 80" anyhow, I'll stick with 3 widely spaced.
Grigg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Grigg, every updating of the regulations includes a "grandfathering" that allows what met the rules at the time a vehicle was produced, like the green color of front markers Jay mentioned to start
Bill | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | My 1939 Chevy 1.1/2 ton COE tow truck originally only had two amber cab lights in front, on each corner of cab. Also it had two red at the back corners of cab. My truck was out of Arkansas.
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well I am planning on putting all the lights I need to bring my 52' 454-30 up to current standards. Currently my truck does not have cab ID lights or rear ID lights. I am putting 5 Amber lights on the cab roof and 3 red lights on the rear of the dump bed.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I also will be doing this on my '42 dump. I'm trying to find era correct even '50s style. I really like the KD 517 model cab light. I recently bought a Beehive 3 lamp light bar from grote #49002 for the rear of the truck that look really good. No offence to what Tim posted, But I think all those styles look cheap. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim [and alltruck72] - those original style teardrop lights [1st you link, like KD 517's] are very scarce new - Arrow Safety had similar until about a year ago that I think were by Grote, but generally they're now an e-bay thing - similar ones can be found at Tail Light King, but good used ones go pretty fast .... used ones with stainless covers are more likely to be restorable than those with plain steel covers Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Bill
I had forgotten about Tallightking
Happy New Year
