| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | I have a 1971 4 wd Blazer and I am trying to ID the front end. It has 44-5F on the web by the pumpkin and also C-31256. Also wondering the value- it is complete with dics brakes/springs etc. Also, on one side where it locks into 4 wd it says "spicer". (white) The other side is plain. (blue)
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The axle is an open knuckle Dana 44, pretty much the standard axle used in GM 1/2 and 3/4 ton 4x4s from '70-'87 (HD option after '77). Sounds like it mght have a set of mismatched lockuots. As far as value, have no idea. It would be worth more if you have the rear axle that goes with it, and sell them as a matched set.
Bill Burmeister | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | OK Thanks. That front axle is a 10 bolt and the rear is a 12 bolt. Would the rear axle have the same Dana 44 on the pumpkin web? Or put another way- How can I tell if I have a matched set? I think u are right about the lockouts. Drivers side look like a spicer and pass. side looks stock. (blue)
