| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | The front leaf springs on my '56 GMC 3/4 ton are almost flat. Replacing them is high on my list. The front end seems a little hoppy- has anyone had tired front leaves and experienced this? Also, is it safe to put on helper springs as a temporary fix?
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Mine are in about the same condition, but I haven't done anything about it yet. My truck sets about an inch lower on the drivers side front as compared to the pass side. I don't know about it being "hoppy" because I've never driven another truck like this. It does have pretty bad bumpsteer when you hit a bump at hwy speeds. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Been looking all over to cure a similar issue on my bus but it seems that all the shops that used to "re-arch" springs have gone the way of the horse & buggy in these parts. Anyone (anywhere) know of a shop that still does this type of work? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i live in suburb of philadelphia pa. we havea place here that I worked at years ago and is still in business, I just used them to re-arch and rebuild my front leaf springs so I could use them on my new 3" drop axle, name of the co. is delaware valley truck spring, on unruh ave. in phila. | | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | I had the springs re-arched on my 76 3/4 ton 15 years ago and they are holding up fine. It gets most of its use as a hauler. Boise springs works did it. They are still in business. I am sure there are many other good spring shops still going around the country.
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Just found that Cotton Brothers here in Houston still does leaf spring re-arching...hoo-yah! | | | | | Joined: May 2005 Posts: 335 'Bolter | | 'Bolter Joined: May 2005 Posts: 335 | This thread kind of got hijacked, and no one answered the original poster's question.  | | | | | Joined: Jan 2009 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 25 | | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I think to answer your question, the condition of the spring eye bolt & bushing, the shackle bushings and pins and if any leaf springs are cracked or broken must be determined.
"Hoppy" might be related to the shocks.
I replaced the front leaf springs, rebuilt the shackles and installed new shocks on the '54 3100 last winter and Oh what a difference it made.
My words of wisdom; be sure to end up with made in the USA parts and do not fall for the cheap Spring Eye bolts.
Good luck | | | | | Joined: Sep 2010 Posts: 27 New Guy | | New Guy Joined: Sep 2010 Posts: 27 | | | |
