1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#892644 10/28/2012 9:59 AM
Ok So I want to replace the inner seal for my windshield and can't seam to find a where to get it,If there is even one to be gotten! I have the outer seal and while the windshield is off i would like to change it if possible. I have looked online and lots of people have the outer but don't list the inner(glass to frame of windshield). Can anybody help me with this? I am sure somebody has changed it out. Thank you guys again for all your help!
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
have you checked with Steele Rubber? I think what you need is called sash filler, to fix the glass into the metal frame [sash], then the windshield seal is the rubber you have that seals the windshield "assembly" to the body opening
I got my rubber parts for my 36 here...
https://www.fillingstation.com/
Hi Bill, After I saw your post I looked it up at steele rubber and they had them under sash filler! thank you again, Dan
Thanks Corpo, I'll check them out too. Dan
Your local auto glass shop should have this product as well.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
Thanks Mike, Got some coming from Steele Rubber. I don't have a local auto glass shop around here...lol Dan
