1 members (Peggy M),
129
Mod | | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Our 1949 Chevy 3600 is hard to drive at night, it doesnt have gauge lighting! Are they supposed to be lit??
TEMPORARY SOLUTION: For those smartphone owners out there. We downloaded a speedometer application that uses the GPS to track your speed... Voila! We can drive the truck at night!!
Just one more tool to add to the box. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The instruments should light up with your headlights. If the rheostat is gone, you can connect your dash lights to the headlight terminal on the headlight switch. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Our 1949 Chevy 3600 is hard to drive at night, it doesnt have gauge lighting! Are they supposed to be There should be two instrument sockets, and a hi beam indicator Here is a pic of my 50 speedo ...pic... the bottom socket is for high beam indicator on my truck. It would be a good idea to get your instrument lights working. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | So that's what it's supposed to look like under there. I always enjoy your great photos. Steve | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I always use my GPS to double check my speedometer or in some of my vehicles where the speedometer isn't 100% accurate. | | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Thanks guys!!
We got the gauge lights working. I had no idea the switch was a rheostat. All it took was s twist | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I use that Speedometer App against my Chebbie truck and Moostangs. Very helpful.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
