5 members (Donf, Shade Baby, sron48, Jon G, Bill Hanlon), 141 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
Seems like I have done it all on this motor. It idles rough and slightly better at higher RPM but not much.
New head gasket-torqued properly
new plugs, wires, condenser, carb, manifold gaskets & alignment rings.
vacuum guage at 21 but bounces to 22 or 23 rapidly even bouncing with high rpm.
Could vacuum advance be contributing to the problem or is this a valve? How bout a lifter? any help appreciated.
Eric
Riding in the Passing Lane
Sounds like a vacuum leak at the intake manifold. Did you check compression? You replaced the head gasket but did you check for leaking valves?I dought if the vacuum advance is causeing this.
1972 Chevy c10 Cheyenne Super
I checked compression after the head gasket replace and all were pretty good and even. I just did the intake gaskets and a little gasket sealer. If its still an intake leak, what is the best way to check?
Sounds like vacuum leak to me too. OLD school method is to spray a bit of carb cleaner around the suspected areas that might leak and listen for RPM changes. Make sure the gaskets and spacer are in good shape and torqued down under the carb.
Keep us posted.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
H Online: Content
I use Propane or acetyline around the intake port/cylinder head junction. It's a lot less messy than carb cleaner. If the idle smooths out or the RPM increases, you've found your leak. Also recheck the valve adjustment. A too-tight intake valve clearance or leaky valve seat can cause the same problems. Do a cylinder leakdown check with air pressure in the cylinders to check for valve seating leakage.
ok will do this weekend. i will ask more monday. thanks guys
With insulated pliers pull spark plug wires off one at a time with the engine idling. If 1 or more cyls. dont change that narrows it down to the particular cyl.
Check that the carb hold down nuts are tight.
I had a split in the flare of my vacuum line where it entered the carb.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
sorry, u lost me on that one. By pulling off a plug wire at idle, will that isolate the cylinder with bad valve?
Eric
Eric
Yes. It will tell you which cyl/s is causeing the problem.
