Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Otto Skorzeny, cmayna, rick46ia, Steelonsteel), 63 guests, and 2 robots.
Topics128,006
Posts1,055,271
Members48,418
#891285 10/22/2012 2:34 PM
1 Offline
chug I've been plagued with an annoying overheating problem that I could not figure out. I installed a 1955 235 in our '36 Low Cab and had the radiator rodded out and it flowed perfect. I installed an electric fan and a modified water pump shortened to fit in between the 235 and the rad. I had constant minor overheating, steam and water coming out of the rad overflow tube any time I stopped, even short distances. I thought , well it's a non pressure system this must of happened all the time to the old timers. I continually put water in. I put a S&W water temp guage in to monitor the temprature. The Temp guage would slowly climb to about 180 and sit there while I crusing at 45 to 50 MPH.then slowly climb to the forbiden zone of 200-210, I pulled over to the first available side street and got out to see steam coming out of not only the vent tube but my exhaust stack as well. Typically not a good sign.I did have the presence of mind to feel the rad at the bottom and it was cold...no flow I thought, what the heck. I shut off the ignition and towed the rig home. Fired it up after it cooled off and had coolant coming out of the exhaust, DANG, cracked head at the exhaust port. I was sick. To make a long story short, When I installed the new engine I had put a new thermostat in that was laying around the shop and my mind was still thinking about closed systems. The thermostat that was in it was a 190, I put a 170 in and all is well with no temp climbing and I can see when the 170 opens. That small mistake cost me a new head and a weeks of down time. $ 5.00 part and man did I learn about open system cooling.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
Man that stinks, It's always the little things we forget to check that are the usual cause of the problems. Well at least it's solved now.
1 Offline
In a total rebuild that takes literally years to do, It sure taxes your memory and you find things you can't even identify left over. All I can say is take tons of pics and go back over all the things you did from the begining. I'm working on my 2nd build and believe me I'm doing it very differant. Think of all the grease zerks I probably missed....lol.
"Murtahg"
