6 members (BarryP, klhansen, dt235sd, Youngin' Tut 59, DadsFirstPickup, 1 invisible), 70 guests, and 2 robots.
Topics128,139
Posts1,056,758
Members48,454
Can't find anything on Rock Auto, or not looking in right place. Need new master cylinder for my 56 2-ton. Anybody have a resource to share? Thanks!!!
Dr. Patrick Hagerman
Scotlea Hot Rods
www.scotlea.com
3B Offline
Hy DrPatrick, rather than use the term "2 ton", please use the model identification number 4400, for example. The most common master cylinder for that year is a 1 1/4" bore unit Raybestos p/n MC21698, available at RockAuto around $130.00. There are other master cylinders as well, 1 1/2" bore cylinders for heavy duty brakes or tandems, they have been made of unobtainium for a few years now, hope that helps.
Try accessorylandtruckparts.com. The address is:10793 Route 61,Hwy 151&61 South Dubuque,iowa 52003. Phone:(563)556-5482. I have to call in an order. Website just gives info. I already provided. This guy's been collecting parts for 35 years,and he's got just about anything for the '41-'59's,from 1/2-ton-3-ton! Hope this helps.
Mo' Tater
I've probably got one of those "unobtainium's", it's a 1st series 55, 6500. What would you call that 2 ton, 3 ton?
3B Offline
Hy MAX1VET, the master cylinder for your truck would be a 1 1/4" unit as well, Raybestos p/n 9220, available at RockAuto for $100.12, hope that helps.
can you get rebuild kits for big bolt master cylinders?
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
3B Offline
Hy Materman, yes you can usually get rebuild kits, if you ask about a specific application I will try and find the p/ns, hope that helps.
i have a 55 2nd 4400 series 1.5 ton that does need a re build kit for the master cylinder, is this the info you need?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
3B Offline
Hy Materman, there are two different master cylinder bore sizes possible for your truck, a 1 1/4" bore is the standard master cylinder, the repair kit for that is Raybestos p/n MK33 $16.16 at RockAuto, the kit for the other master cylinder with a 1 1/2" bore (with heavy duty booster) is Raybestos p/n MK209 $29.79 at RockAuto, hope that helps.
Thanks guys!!
Scotlea Hot Rods
www.scotlea.com
