0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
Ive been having fuel issues and pulled carb apart. the end of the rod on my power piston was burred and i cleaned it up it sand paper, and still haveing problems, i noticed that in a exploded diagram of the rochester b, there is supposed to be a spring then a ball under the power piston. I only had the ball, no spring, would this be3 the reason no fuel is gettin into my carb? Where can i find another power piston? thanks for any help u guys have!
Try this guy for a power piston.
http://www.thecarburetorshop.com/
I believe the spring your missing comes with a rebuild kit. Here is a on line manual. Maybe you will find it useful, or at least interesting.
http://chevy.oldcarmanualproject.com/booklets/5020mts00.htm
The kits are available at Napa. Pretty cheap and come with all new balls and springs. As well as new leather for the accelerator pump. Made a huge difference for my truck
I put a rebuild kit in but i guessed i lost the spring when the nut that hold the spring/ball/power piston came loose and dropped into the bowl.
i have two diff springs in my rebuild kits left , i pretty sure it is one of these thats goes below the power piston.
Does anyone know if its a small, cylinder shaped, very stiff spring Ive seen called a power valve spring, or is t the spring that's longer, and tapered soft? thanks again
