| | | Forums66 Topics128,042 Posts1,055,602 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | Ive been having fuel issues and pulled carb apart. the end of the rod on my power piston was burred and i cleaned it up it sand paper, and still haveing problems, i noticed that in a exploded diagram of the rochester b, there is supposed to be a spring then a ball under the power piston. I only had the ball, no spring, would this be3 the reason no fuel is gettin into my carb? Where can i find another power piston? thanks for any help u guys have! .. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | The kits are available at Napa. Pretty cheap and come with all new balls and springs. As well as new leather for the accelerator pump. Made a huge difference for my truck | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I put a rebuild kit in but i guessed i lost the spring when the nut that hold the spring/ball/power piston came loose and dropped into the bowl. i have two diff springs in my rebuild kits left , i pretty sure it is one of these thats goes below the power piston.
Does anyone know if its a small, cylinder shaped, very stiff spring Ive seen called a power valve spring, or is t the spring that's longer, and tapered soft? thanks again | | |
