1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#891147 10/21/2012 11:41 PM
I have my transmission, 4 speed, setting on a bench for cleaning and painting with the clutch gear facing down. Fluid is dripping down the shaft. When I look in the shop manual I do not see a seal on this shaft. Should I be leaking out this shaft or do I have a problem. I had not planned on rebuilding this tranny as it worked fine when I drove the truck before everything was tore down.
If you never tell a lie, you never need to remember what you said.
There is no seal on the input shaft, just an oil slinger.
My Blog
