| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I have my transmission, 4 speed, setting on a bench for cleaning and painting with the clutch gear facing down. Fluid is dripping down the shaft. When I look in the shop manual I do not see a seal on this shaft. Should I be leaking out this shaft or do I have a problem. I had not planned on rebuilding this tranny as it worked fine when I drove the truck before everything was tore down.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is no seal on the input shaft, just an oil slinger.
See the USA in your vintage Chevrolet! My Blog | | |
