| | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89106 10/31/2002 3:33 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | I finally finished wiring the aftermarket turn-signals in my 53. I added smaller lights out back Rick\'s truck . It works great and I feel much safer driving in downtown traffic! One thing bothers me though: I cant hear the flasher. It emits a very soft tchik-tchik-tchik... The result is I almost always forget them on. A friends says you can buy either a noisy or quiet flashers, is that so? rick | | |
#89107 10/31/2002 4:11 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Yes, it's an extra loud flasher relay. J.C. Whitney has them,; as well as most chain-type auto parts stores.
*** GMC ***
#89108 11/01/2002 1:30 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I had the same problem. I got a cheep beeper from Radio Shack like they use for backup alarms and wired it to the flasher. Now it beeps when the flasher is "open".
if it dosen't need fixed, break it
#89109 11/01/2002 2:33 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I used part # 273-054A, a mini-buzzer off the shelf at Radio Shack at $2.79. This one is 3-7 volts, but they also come in 12 volts or greater. Just wired it between two of the flasher poles. Even tucked up under the dash it is plenty loud to serve as a reminder the turn signal is on. If it's too loud, put a piece of tape over it. | | |
#89110 11/01/2002 2:41 AM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | Sorry I could not help my self.
Change the battery in your hearing aid. :-) | | |
#89111 11/01/2002 6:14 AM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 | :)howziit guys!
how about installing/wiring up a solenoid in the seat, timed to poke you in the back, if the turn signals are left on too long. :rolleyes: :rolleyes: :rolleyes:
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#89112 11/01/2002 2:17 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Texaholic, great tip! That's just what I need. I'm off to Radio Shack (darn, havent been there in decades!). | | |
