2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#89041 02/12/2002 4:05 AM
I know I should give it up but...
I just got a cigarette lighter for my 1949 GMC 3/4 ton. It did not have one previously. I can't find a wiring diagram in my assembly manual for the lighter and I didn't find this info in the archives. Does anybody know how and where this is wired. It has a post on the back of the lighter and a tab on the side. The truck is converted to 12 volt. :confused:
Murph
#89042 02/12/2002 4:10 AM
We are not going to tell you,,,,, you want to quit smoking right? grin grin
The tab on the side is the ground(negative wire)
The center post is for power(positive wire)
#89043 02/12/2002 4:13 AM
Anonymous
Unregistered
Anonymous
Unregistered
Kevin , the post is the hot lead & the tab is the ground. Is the lighter element a 12 Volt also?
How did the spare tire carrier work out?
#89044 02/12/2002 4:24 AM
Got which wire is which, thanks. Where do I hook them up to the ignition switch? Yes it's a 12 volt lighter. Just got the tire carrier back from the sandblaster. It came out great! I'm going to paint it as soon as I'm done with the lighter.
Murph
#89045 02/16/2002 1:39 AM
Dont hook to your ignition switch. The ligther will pull too many amps. Run a new (fused) wire dedicated to the lighter. Most factory lighters are sepearte from the ign. switch. Use at least a 10 amp fuse.
