2 members (jay d, Gdads51),
75
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89041 02/12/2002 4:05 AM | Joined: Jan 2002 Posts: 11 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 11 | I know I should give it up but... I just got a cigarette lighter for my 1949 GMC 3/4 ton. It did not have one previously. I can't find a wiring diagram in my assembly manual for the lighter and I didn't find this info in the archives. Does anybody know how and where this is wired. It has a post on the back of the lighter and a tab on the side. The truck is converted to 12 volt. :confused: Thanks Murph | | |
#89042 02/12/2002 4:10 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | We are not going to tell you,,,,, you want to quit smoking right? The tab on the side is the ground(negative wire) The center post is for power(positive wire)
#89043 02/12/2002 4:13 AM | | Anonymous Unregistered | | Anonymous Unregistered | Kevin , the post is the hot lead & the tab is the ground. Is the lighter element a 12 Volt also? How did the spare tire carrier work out? | | |
#89044 02/12/2002 4:24 AM | Joined: Jan 2002 Posts: 11 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 11 | Got which wire is which, thanks. Where do I hook them up to the ignition switch? Yes it's a 12 volt lighter. Just got the tire carrier back from the sandblaster. It came out great! I'm going to paint it as soon as I'm done with the lighter. Thanks Murph | | |
#89045 02/16/2002 1:39 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Dont hook to your ignition switch. The ligther will pull too many amps. Run a new (fused) wire dedicated to the lighter. Most factory lighters are sepearte from the ign. switch. Use at least a 10 amp fuse. | | |
