| | | Forums66 Topics128,143 Posts1,056,786 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 32 | Can't find anything on Rock Auto, or not looking in right place. Need new master cylinder for my 56 2-ton. Anybody have a resource to share? Thanks!!! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy DrPatrick, rather than use the term "2 ton", please use the model identification number 4400, for example. The most common master cylinder for that year is a 1 1/4" bore unit Raybestos p/n MC21698, available at RockAuto around $130.00. There are other master cylinders as well, 1 1/2" bore cylinders for heavy duty brakes or tandems, they have been made of unobtainium for a few years now, hope that helps. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Try accessorylandtruckparts.com. The address is:10793 Route 61,Hwy 151&61 South Dubuque,iowa 52003. Phone:(563)556-5482. I have to call in an order. Website just gives info. I already provided. This guy's been collecting parts for 35 years,and he's got just about anything for the '41-'59's,from 1/2-ton-3-ton! Hope this helps. | | | | | Joined: Oct 2012 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 15 | I've probably got one of those "unobtainium's", it's a 1st series 55, 6500. What would you call that 2 ton, 3 ton? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy MAX1VET, the master cylinder for your truck would be a 1 1/4" unit as well, Raybestos p/n 9220, available at RockAuto for $100.12, hope that helps. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | can you get rebuild kits for big bolt master cylinders?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Materman, yes you can usually get rebuild kits, if you ask about a specific application I will try and find the p/ns, hope that helps. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i have a 55 2nd 4400 series 1.5 ton that does need a re build kit for the master cylinder, is this the info you need?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Materman, there are two different master cylinder bore sizes possible for your truck, a 1 1/4" bore is the standard master cylinder, the repair kit for that is Raybestos p/n MK33 $16.16 at RockAuto, the kit for the other master cylinder with a 1 1/2" bore (with heavy duty booster) is Raybestos p/n MK209 $29.79 at RockAuto, hope that helps. | | | | | Joined: Mar 2011 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 32 | | | |
