0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
I have searched the previous postings for this information but have not had much luck. Was hoping someone could confirm with me the proper point gap setting for my 1954 235 that I have added a new higher output coil.
I am going with a 12 volt system with a new Petronix Flame Thrower coil (40,000V 3.0ohm) with standard points. AC R45S plugs are gapped at .016.
For the initial start up of my newly rebuilt engine, should I be setting the points at .045 or does anyone else have a preferred setting that has worked.
The 1954 Shop Manual shows .016 for used points (.019 for new), and .035 for plugs.
I think you have your settings reversed?
I set the plugs at .040 with the Pertronix ignition (as recommended by Pertronix), and at .035 when using points.
Thanks for the information Tim...guess I did get my numbers transposed!! I thought the spark gap was widened a bit but was not sure if I needed to increase the point gap as well using the Pertronix coil.
I really appreciate the information everyone gives here on the forum.
The Pertronix coil without an igniter module is like peas without carrots or potatoes without gravy. My last set of points have been waiting in the glovebox in a ziploc bag for a long, long time waiting for emergency duty/starting difficulty.
You Tube
