2 members (NJC, 1 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#88974 02/17/2002 4:23 AM
I have a 52 GMC Diesel and it has a huge 12 volt battery under the floor in truck. But, get this....the running board has to be removed to get it out of holder on frame side. Hole in floor is small as other trucks, no way it's going out that! Darn thing is 20" long or so at least, 10" wide maybe. Posts are at one end. Don't know what amps it's supposed to have, but I'm sure plenty. The starter on this things about 2ft long too! eek Not sure if it's positive ground like the 6volts, gotta check that yet.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
What you probably have is an 8D battery.. Get help before lifting it, they are man killers..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#88976 02/18/2002 12:38 AM
In a past life I was in a Volunteer Fire Department and one of the trucks had a factory made body, and had a battery box that took a battery the size your talking about and it was 12 volt. I can't remember the numbers though. As for how it would come out of your truck I'm not sure, sorry I know thats not much help. But as Bill says better to have two people.
Dave H.
We use them on our fire apparatus, Dave. Our larger engines each have two of those 8D batteries, they have a 24 volt starting system. Those batteries come with a pull up handle on each end. One for you and one for the poor sap that has to help you lift.
Bill M
53 GMC Hydra-Matic
Home Page
What are you guys, a bunch of sniveling wimps? The 8D isn't that heavy. I can move them around, and I have a bad back. What we need in here is a real man, a Marine, to rag on your sorry axxes and browbeat you into submission. Sounds like time for some pushups for you weaklings. First the ones with one arm, then the kind where you get to applaud for yourself. Your only talking about 160 pounds!
Fred
52 3600
69 C-10
FredT Wrote:
"I can move them around, and I have a bad back."
Um....Fred....ever think this may be the REASON you have a bad back?
Beat it to fit...Paint it to match.
Uh, I'm a Marine, and a battery that heavy I'd just blow it in place. grin
If you can't move it, call in an air strike.
-=Hairball=-
Junior Member
Junior Member
I'd try to run two heavy (900cca)12 volt batteries in parallel. Will produce about 1800 amps at full load, and easier to find (Sears) than current battery. Probably cheaper to but I'm just guessing on that one. If you need more power than that get a new truck, or start it from a 3 phase 440volt outlet.
Try you local John Deere Ag or Construction dealer (not a Lawn and Garden equipment dealer). 8D batteries are in many pieces of Agricultural and Construction equipment.
