0 members (),
172
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I don't think JB Weld will hold up to the heat. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Thats the exhaust port, you would be better off using high heat silicone,(red). it will hold up with no problem, I have used it instead of gaskets on race engines using headers. It will work. I think the JB weld might not hold up that good, it will get too brittle from the heat. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Here is your answer from the JB Weld site JB Weld FAQ Basically it says JB Weld will hold up to 500 Degrees F. Continuous temp, 600 intermittent.Not recommended for exhaust manifolds, but I'm thinking the head itself won't get that hot. They also have a high heat product they recommend for exhaust manifolds: high-heat That would probably work. Kurt | | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Thanks All !!
Me and my '53!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | When I read the title/question I thought to my self "no way, do the machine work to fix it properly..." But looking at the pictures whatever you put in there will be trapped by the gasket so as long as it'll hold together and not turn to dust it might just work.
Grigg | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a copper filled RTV that is for high heat uses. I have used it for ex. manifolds with good results. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | There is a ceramic paste for high heat sealing to 1200 degrees F--used commonly by the people doing repair on steam systems(turbines, valves,joints, etc) that would work great here.The brand I am familiar with is called "copaltite". If you have a friend in plant maintenance he might find a little. I have often wondered about the "muffler sealants",that have been around since work began on Noah's ark, for this purpose. Actually I think what I am seeing in your pics will seal with only a standard gasket-just retighten after a while and keep it tight.
Bob Taylor
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Standard gasket and and copper RTV will do just fine. Let it dry a while before starting. I would bet if you take a flat sanding block and hit those ports a little, it won't look nearly as bad as you think it does.
Joe | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | The machine shop where I used to run the connecting rod reconditioning department had a BIG belt sander for cleaning up gasket surfaces like that. Just a quick pass over those pits on such a machine would be the best choice, but a very high-temp filler would be the next best thing. J-B Weld won't hold up to the heat present at that junction. Jerry
| | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Thanks everyone - I went with the Copper RTV
Me and my '53!
| | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Does anyone know what the proper torque value for Manifolds should be? I just tightened them down real snug and they seem to be fine no leaks
Me and my '53!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Thanks very much I'm going to loosen things up and redo it tonight using the specs you provided
Me and my '53!
