9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible),
153
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I know there are aftermarket kits out there but does anyone know of any reg that canbe pulled out of other cars or truck that go in with lil to no mods if so what should i look for to pull them out of?
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good question, one you might get better results for over in the HiPo forum. My feeling on the subject is this; from what I've seen the job of installing power windows is fairly complicated and not one I would want to attempt with just any regulator and one I probably would have to do additional fabrication. Just my 2 cents.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | BTW I just saw your pics. That's a great looking truck Bud.
~Jim
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Big Ton
I highly recommend the Specialty Power Window Company ... I believe they are in Georgia or Alabama ...
I bought their kit for the AD trucks ... Fits and works perfectly and best of all Made In USA. They are NOT the cheapest but compared to some of the junky plastic and Chinese stuff being offered out there ... their stuff is no contest. You can also call them with questions!
(They also have a slick wiper kit to replace the old AD system that I intend to install.)
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | im not afraid of drilling whole or making brackets for my door was just wondering if anyone had found a reg that work with a lil mods and saves some $$ | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've tried several types over the years and have yet to find one that works good. I'd always end up selling them and going back stock. If your manual regulators are in good shape, there is kit you can get on Ebay for less than $100, but its not a clean install. They use adapters that mount to your existing regulators. I also tried these but never could get them adjusted quite right. The best kit I've seen IMO is the Nu-Relics unit. They're a direct bolt in but they're not cheap!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I've tried several types over the years and have yet to find one that works good. I'd always end up selling them and going back stock. If your manual regulators are in good shape, there is kit you can get on Ebay for less than $100, but its not a clean install. They use adapters that mount to your existing regulators. I also tried these but never could get them adjusted quite right. The best kit I've seen IMO is the Nu-Relics unit. They're a direct bolt in but they're not cheap! Right on good info thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ..The best kit I've seen IMO is the Nu-Relics unit. They're a direct bolt in but they're not cheap! I casually browsed the electric window options myself and also came up with the same conclusion. And decided there's nothing wrong with the original crank and it's certainly cheaper and more reliable than any electric window, I'll stick with stock. Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | ..The best kit I've seen IMO is the Nu-Relics unit. They're a direct bolt in but they're not cheap! I casually browsed the electric window options myself and also came up with the same conclusion. And decided there's nothing wrong with the original crank and it's certainly cheaper and more reliable than any electric window, I'll stick with stock. Grigg For some of us the best (cheapest/solution)way would be to add air conditioning and keep the windows up. lol
~Jim
