| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi
Took one of my rear leaver shock apart tonight to see whats inside, what I found out was I had no oil does anyone know how much oil to put in, might as well find out how much goes in the front as well, also what do you think about putting some of the lucas hydraulic stop leak do you thing it would seal up any leaks Thx
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Jack oil is used, thick oil or stop leak will make them "hard" I think. Fix the seals and fill to fill hole. They are also called knee shocks.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Or you can have them rebuilt for a whopping $150 each with a one year warranty. | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | They are also called knee shocks. We always called them Grass Hopper Shocks.
See the USA in your vintage Chevrolet! My Blog | | |
