| | | Forums66 Topics128,050 Posts1,055,751 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Can someone tell me the best way to install the weather rubber strip around the windsheild of my '42 Chevy p/u?
Ridge dweller
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Start with a quality rubber insert. The first one I bought obviously was made offshore. It was hard and inflexible. Someone recommended Steeles Rubber products. Theirs was very easy to install / slid into the " Tee " slot like a dream. Steeles recommended a 3M adhesive to use on the butt joint that worked great. The softer rubber also seals better against the body to minimize leaks and drafts. | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 |
Ridge dweller
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Place it around the glass first. set the car and windshienld in the sun. It helps warm up the stiff rubber. Place a string inside the rubber channel all the way around. Put windshield in place and start working the body into the groove, and use the string to help with the lip. Take your time. It helps to have another helper. Don't bang too hard on the glass. Use your open hand. Good luck. | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Thanks cvett, thas great news. I used to live in Lexington.
Ridge dweller
