1 members (baldeagle),
30
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I've got exhast gas in the radaitor on a 53 2 ton with a babbit 235, is the head the usual culprit as far as being cracked, or is the block prone to cracking also, I won't get it apart for a week or two at this stage. Thanks | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | The head is most likely , or its got a blown head gasket, The blocks are very strong,Blocks do crack if they are frozen. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Block cracks from freezing are usually to the outside, and result in coolant leaks, not compression in the radiator. Pull the head and look for warps or cracks, or a simple blown gasket. A quick check for warp across the top of the block can be done with a big, flat file. Draw-file the top of the block with a firm down pressure and long strokes. A uniform scratch pattern indicates it's flat enough to seal a head gasket. Ditto for the sealing surface of the head. Jerry
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Thanks, I kinda figured a head, it doesn't do it till you drive it and lean on it pretty hard,no water in the oil, do all the 235 heads work on the early blocks. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I'm still finishing some small stuff on this truck and some body put a fire wall pad in from who knows where, and it is not a decent fit at all, has anybody found a pad that fits correctly not 2" short. | | |
