3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#889377 10/14/2012 6:48 PM
Trying to locate a Bushing remover tool. All ready check with the Filling station, Chevys of the 40's and NCA, no luck finding one, any ideals where I can buy one? Thanks Rob
The Filling Station lists them, are they out?
Filling Station Listing
My Blog
Classic Parts of America lists one. bushing puller
Tim
1951 3100 Chevrolet
"okie" or "oakie" bushing
http://www.chevsofthe40s.com/detail/6272/Chevrolet_Oakie_Bushing.html
original-style propeller shaft bushing (I think)?
http://www.chevsofthe40s.com/detail/6270/Chevrolet_Propeller_Shaft_Bushing_Rear_12.html
Chevs of the 40s also "rents" the puller for an enclosed driveshaft bushing . I do not know if it long enough to pull an Okie bushing (maybe someone with first-hand experience will respond)?
The bushing pullers linked to will not pull an Okie/ Oakie.
My Blog
Rob,
If you've got the driveline pulled out, a 6' or so length of pipe jammed up the torque tube will knock it right out with a little applied force with a sledge.
If my memory is right, the earlier types had a small metal dowel holding the bushings (2 of them) in place which needs to be removed.
What year of truck are you working on?
Jeff
My 1953 Chevrolet
1947.1 Gallery
Originally Posted by rustednuts
Rob,
Jeff
More specifically, a 6' length of 1" pipe with a pipe coupler screwed to the "business" end. Make sure the couple OD is a tad smaller than 1.625" or you will only be pounding on the "step" inside the torque tube.
